Compensator changes for 2014..retro kit will be available!
More oil groves, primary oil flow director, tapered bolt, grooved sprocket...and there will be a retro-kit for earlier models...here we go:
https://lh3.googleusercontent.com/-w...m+cut-away.jpg https://lh5.googleusercontent.com/-c...ed+diagram.jpg https://lh4.googleusercontent.com/-R...amp+change.jpg https://lh5.googleusercontent.com/-r...ape+change.jpg https://lh6.googleusercontent.com/-H...g+passages.jpg The picture below is part of the retro-fit kit. This part is designed to deflect primary oil toward the compensating sprocket. This is for pre-2014 models. The 2014 models will have a metallic webbing molded into the primary cover to accomplish the same re-direction of primary lubricant to the compensating sprocket: https://lh3.googleusercontent.com/-p...ervice+kit.jpg That's it for the new compensator. Apparently the same primary chain tensioner is being used. |
Where can I download the file you are showing here. Do you have a link?
it is called the
2014 model year technical forum you may find it on the web with a search engine, links to it have been posted by a few members, but the mods have removed some of the threads... I am starting to wonder how long until we have dual clutch packs in the primary...one at each end! Mike |
I would say this is as about as close as we will see that this is an admonition from the MoCo that there IS and HAS BEEN a MAJOR PROBLEM with compensators in the Big Twins. With 46K on my original in my 2010 StreetGlide, I am still waiting for it to blow up!
Had a compensator replaced at 50K on my 07 FLHTC, and at 30K on my 12 FLHTK. Next compensator failure/replacement gets this upgrade. Hope it helps. Looks like they determined root cause of failures to be lubrication and cam profile. Sounds reasonable, but only time will tell.
Its not clear that these modifications will bring lots of improvement :icon_frown:
Wider cam ramps should lessen wear on the spokes as long as their contact surfaces are sufficiently lubricated and the same case hardening/nitriding is applied to both spokes and cams; the axial roller bearing will only rotate/oscillate by a few degrees, so its longevity seems compromised. |
26,000 and already replaced it once. Now it is starting to make noise again.
why in the hell did they use a dam torx bolt. i hate them things,wait till you strip that out.
Why did they wait sooooooooo longgggggggggg to fix it when they knew it was literally a wink link?
wonder how using synthetic oil would work on the new "roller element bearing" sorta like the old cam bearing?
© 2024 MH Sub I, LLC dba Internet Brands
