Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Touring Models (https://www.hdforums.com/forum/touring-models-11/)
-   -   Won't start..... (https://www.hdforums.com/forum/touring-models/908250-wont-start.html)
3/4 life crisis Sep 16, 2013 03:57 AM
Won't start.....
Going down the road, seems like ignition/fuel cutoff for a second, throttle it back up, kept going. Upon shut off, engine won't start back up, unless I throttle it as I'm starting, almost every time it drop back to idle, it tends to die. Any ideas? TIA
grbrown Sep 16, 2013 05:12 AM
It is likely your battery is low on power, either because it is at death's door, or your charging circuit is misbehaving. Go to the DIY Electrical section, where you will find Stickys giving hints and tips on diagnosing your charging problems. You will need a multi-meter.
3/4 life crisis Sep 16, 2013 07:31 AM
It seems to crank ok, just didn't "catch" unless I roll on the throttle as I am cranking it. I think it's somewhere in the TBW or a sensor. Also, no code either.
© 2026 MH Sub I, LLC dba Internet Brands
