roller rockers
Old Oct 29, 2013 | 09:17 AM
ballbreaker69's Avatar
ballbreaker69
Talking roller rockers
Getting ready to put the bike away for winter. For the last month it has been getting quite noisy in the top of the motor. I have 55,000kms on my 2010 road king. I am going to take the top off and check the rockers. If they need replacing I will probably replace with roller rockers. Any brands any better than another and what else should I look at replacing. This is a stock 96 engine so I don't know if rollers are overkill or not. I hear that they last a lot longer and I am not planning any other mods. All opinions are appreciated as this is my first Harley.
Old Oct 29, 2013 | 10:47 AM
fwb35's Avatar
fwb35
Roller rockers are better, they reduce friction wich reduces heat and make more power. The cost is way high, I can buy a set for my race car, 16 roller rockers for less then the cost of 4 for my Harley, I have 63k miles on mine and they are fine, you might want to look at the lifters causing the noise, I replaced mine and that made it much quieter, get a good quality lifter and I bet your noise goes away.
Old Oct 29, 2013 | 06:10 PM
Oldpanrider's Avatar
Oldpanrider
I put the S.E roller rockers in my '07 Nightrain when I did the Stage 4 kit on it, along with the forged rocker stands. Seems to work pretty well. Pricy but works well. Might be over kill for a fairly stock engine.
Old Oct 29, 2013 | 06:36 PM
0ldhippie's Avatar
0ldhippie
I put S&S roller rockers in my 103 upgrade just because I had them left from another build I never put together. But they are really overkill for much of anything under .600 lift. They were never designed for high mileage riders.
Old Oct 29, 2013 | 06:45 PM
soft 02's Avatar
soft 02
All motors make noise. Some more, some less. Dont do the roller rockers. S&S makes a nice forged rocker with 3/4 bushings. Look at Woods rocker supports. They move the pushrods closer to center. They are offset .030 Check your rocker side movement.
Old Oct 29, 2013 | 06:47 PM
ballbreaker69
thanks for all the advice. I will be looking at changing the lifters as well. Don't know until I take it apart to see all what I need. This roadking I will be keeping for a long time so I don't mind spending the extr $$$. I will check out the SE ad S&S rollers as well. I will check out the Woods rocker support. Did not know they made them. Thanks again
Old Oct 29, 2013 | 09:30 PM
tubeman426's Avatar
tubeman426
Don't waste your money, the factory rockers are quite good. Especially for anything .600" lift or under.
Old Oct 30, 2013 | 09:40 AM
dougbk's Avatar
dougbk
I wouldn't worry about putting in rollers for a stock twin cam motor. Older motors are a different story due to the angle of the pushrods. At that mileage I would replace the lifters. Most likely the source of the extra noise. JMHO
Old Oct 30, 2013 | 10:20 AM
OldPhat's Avatar
OldPhat
Roller Rockers work great, but not to cost effective on a street enigen. That being said
if get some you want full roller bearings on the rocker shafts for less heat and friction.
Old Oct 30, 2013 | 11:05 AM
Lonewolf176's Avatar
Lonewolf176
Save your money.
