What's the secret?
What's the secret?
So I am installing apes... not going too bad I might say, until I ran into a block. Now I know from my searches that running internal cables is PitA! I am trying to run the throttle side, but can't get the TBW all the way through... even when I pull it solo. I thought running the the clutch side was going to be the bad one, boy was I wrong
Bike: 2009 Ultra Classic
Bars: LA Choppers Twin Peaks
So my question before I bring it to the local bike shop to have then wire it... What's the secret to running the TBW?
Patience.
High-strength fishing line to use a pullers
Patience.
KY/vasiline....coat the harness with some of it to help it slide down the tube & around corners.
More patience.........
Oh, needle-nose pliers to pull apart the plug ends.
And make sure you label the wires so you put them back together in the right order.
Oh, and lots of patience.
Patience.
When installing bars I generally suck a string through with a shop vac and then use it to pull the wiring through the bars. I remove the plug and fold the wires back in a staggered pattern then tape them down. This is a much more clean way than cutting and soldering wires.
I then use a little bit of lubricant like they use for pulling wires through conduit. I bought a bottle of it from a local electrical supply house and don't use any more than I have to, then just wipe off the excess as much as possible when compete.
Mike.
Mike.
