Bent fork tubes- Need some help/advice
Old Mar 12, 2014 | 05:36 PM
'05Train's Avatar
'05Train
CCE upper tree, Monotubes, Brembo upgrade.
Old Mar 12, 2014 | 05:45 PM
X Iron Butt's Avatar
X Iron Butt
Be careful using the lower tree without a good examination. They tweak very easy from accidents. The upper is pretty stout. If you can get a set of straight tubes slide them up almost to the upper and check for alignment with the lower clamp bolts tight. Any miss alignment can allow you to still assemble them but it will come out at the axle end and you will be driving down the road with your bars not centered straight. You can sight them from the side and see if the tubes are running parallel but it is difficult to see 1/8 inch out of parallel.
Old Mar 12, 2014 | 07:24 PM
Brewser80's Avatar
Brewser80
Thank you guys, much appreciate the info. X Iron Butt, that's a great way to check the tree, hadn't thought about doing it that way. I'm planning on just not using those lowers just to be safe. Damn that CCE set up is pricey. Don't know if I can swing it.
talon0930, So the 08-13 lowers are different than the 00-07's to accommodate the axle size? Are the fork tubes for those years the same?
Old Mar 12, 2014 | 07:36 PM
Joe2010ultra's Avatar
Joe2010ultra
2008 to 2013 tubes are not the same length as 2006. Ask me how I know, not a good story
Old Mar 12, 2014 | 07:58 PM
0ldhippie's Avatar
0ldhippie
Again, '00 - '13 lowers are the same and can use either 1" or 25mm axels.
Old Mar 12, 2014 | 08:02 PM
Joe2010ultra
Agree. But The tubes are not the same length.
Old Mar 12, 2014 | 08:42 PM
Brewser80's Avatar
Brewser80
Oldhippie, do you know for certain the 3/4 inch axle lowers are different? If the lowers are the same 00-13, why aren't the tubes?
Old Mar 12, 2014 | 11:20 PM
0ldhippie's Avatar
0ldhippie
I know earlier, '99 down 3/4" lowers for sure have different caliper mounts. Tubes are different because of different valving internals (pretty sure fl softails are longer overall).
Old Mar 12, 2014 | 11:50 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by talon0930
No Brewser80, you can not. Axle size is specific to the lower sliders.
Yes you can , they make reducer bushing for the smaller axle/bigger bearing setups . What you have to watch for is correct wheel & rotor spacing , sometimes you have make or shim things . I've converted several older 3/4" axle fronts to use the larger bearing late model wheels . I've also taken 1" axles for the later lower legs and had the bearing surface cut down to 3/4" to use the older timken bearing wheels .
Old Mar 13, 2014 | 06:49 AM
modes's Avatar
modes
Friend of mine used to deal American Ironhorse bikes. He was running sliders off a chopper on his Streetglide. Single brake and much nicer bottom to the sliders. Something to look at for an option....
