K&N oil filter... stuck! now what?
04-21-2014, 04:19 PM
Quote:
Originally Posted by
howitzer88
Pound a flat blade screwdriver all the way through the side body of the filter and rotate CCW.
First tap a hole in the end to drain most of the oil out of it. This is what I had to do for a buddy of mine.^^^
Reason: Sp
04-21-2014, 04:20 PM
I've used the "pound the screwdriver through" trick before and it worked well.
This after a service from harley Davidson STEALERSHIP!!!!!
GOOD LUCK.
04-21-2014, 04:29 PM
Check out this 3 jawed oil filter wrench. I'm sure you could find one locally.
04-21-2014, 04:37 PM
Boomer1143
I don't think you get the clearance needed on a harley. Screwdriver or strapwrench works best, imho
04-21-2014, 04:49 PM
Got this one at my dealer... Put a socket on the nut, as you turn the ratchet, the claws grip tighter - no filter too tight to beat it.
04-21-2014, 04:52 PM
Just had that happen on my softail. Put a set of 460 channel locks on it right by the base of the filter. There isn't much room to turn it, but I managed to inch it off a little at a time. Tried the strap wrench too... Had the same problem, not enough room for the handle.
04-21-2014, 04:59 PM
shooter5074
But here's another idea
This method will work and with less mess. They're cheap at your local parts store.
04-21-2014, 05:00 PM
Weavr99FLHT
Had one of those.
Tossed it in the trash.
Junk, IMHO.
04-21-2014, 05:09 PM
Harbor Freight....Less than $10.
I use them all the time,They work great
04-21-2014, 05:14 PM
Greezey Rider
Best oil filter tool ever made. Mine is made by Channelock and sells for about $25.
