K&N oil filter... stuck! now what?
I have always used the K&N oil filter on my FLHX because it was so easy to get off and on with the nut. Until now! Just went to do the first oil change of the year, drained the oil, went to remove the oil filter, used the correct size socket, the "nut" slightly crushed and deformed, now no socket fits. Tried a strap wrench, just no room to turn the handle, I need ideas, anyone ???
I had that happen once. Used an awl and drove a hole all the way through at an angle that gave me clearance to use the awl handle (or a screwdriver inserted) into the hole to turn it and then pulled it out and spun it off. You may even need to do it a couple of times as it turns to loosen it enough to spin by hand if you don't have a lot of clearance to turn very far.
Location: Western Illinois, land of bad roads, and corrupt politicians
You're right, I forgot they changed them.... I have a bunch of the old ones from K&N, and they do have the ribs for that wrench.... but they are like 10 years old.
But here's another idea
