Daymaker: Both the Hi and Low Beam on?
I tried to do the same thing. I figured if I'd put a jumper wire from low beam wire to high beam wire, both would come on! Not so!! I figured there must be a diode inside the sealed light itself not allowing current to travel to both ( high and low beam) at the same time! Got the idea from the trucklite after how I saw how there low and high beam works. Like stated earlier, AMPERAGE draw would have been minimal since they're LEDS.
The projector style Daymaker that comes out on the new Ultras and Limiteds only burns one at a time. The low beam goes off when the high beam comes on. The reflector type Daymaker is different. The top half lights up for low beam and both top and bottom light up for high beam. Personally, I wouldn't take 100 of the projector type if someone was to give them to me. It's just not suited for motorcycle use. The reflector type is much better suited. It's not perfect because the high beam could be greatly improved upon but it is still the better of the two.
Zman15
2014-2023 Touring Models
20
05-23-2015 05:36 PM
HarryDavidson
01-18-2009 05:54 AM
