Where is my ground near my battery? Ultra Limited.
Been getting some buzzing when using my LED turn signals and one of the suggestions that Custom Dynamics had was to move the negative wire of my control module to the 'ground' instead of the negative terminal of the battery.
They said it should be located in front of the negative terminal of the battery. However I am not seeing anything that looks like a ground in front of the negative terminal. Anyone know where this is? 2013 Ultra Limited.
Haven't pulled off the side cover yet to check over there. Will do that shortly.
Unless its a metric size? It seems like none of my standard sizes are fitting properly but I only have a few deep socket ones so I am not sure if I am just not able to get it on there properly without an extender or if its some off-size I don't have. Maybe I can get a wrench down there to at least check the size unless someone knows off-hand.
Location: Western Illinois, land of bad roads, and corrupt politicians
hogwings
16
06-01-2011 07:56 AM
