Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Touring Models (https://www.hdforums.com/forum/touring-models-11/)
-   -   HD 12V Saddlebag Port Has Power, But Won't Charge IPhone? (https://www.hdforums.com/forum/touring-models/976251-hd-12v-saddlebag-port-has-power-but-wont-charge-iphone.html)
drspencer Jun 16, 2014 04:35 PM
2011 Street Glide.
12V HD saddlebag power port, wired directly to the battery.
Getting a constant 12V (checked with meter), but this port won't charge my Iphone 4S.
Tried using different charging cords, but no luck.
I'm baffled, any ideas?
Thanks
mkguitar Jun 16, 2014 04:44 PM
check your usb/ 5 volt phone charger thingy, the ones with an led are better as I know that I have missed contact in my car, truck and bike.
you may need to rotate the plug to make contact
mike
Pioneer74 Jun 16, 2014 04:46 PM
You sure the polarity is correct? +12v is on the center contact.
bundy43 Jun 16, 2014 04:49 PM
and the out side case is grounded
drspencer Jun 16, 2014 04:56 PM
mike
I tried two different charging cords (1 w/LED).
They both work in my trucks cigarette lighter, and neither work with the HD charging port.
Thanks
drspencer Jun 16, 2014 04:57 PM
Yes, the center of the 12V power port is positive (+), the sleeve in negative (-).
Thanks
drspencer Jun 16, 2014 04:58 PM
Yes, center is positive.
Don't know about the outside case.
Both pos. & neg. wires are wired directly to the battery (via a fuse).
Thanks
bundy43 Jun 17, 2014 07:34 AM
is the fuse any good ?
TennesseeJed Jun 17, 2014 07:37 AM
check your ground...
Crimson Jun 17, 2014 08:30 AM
Connect the negative to the ground instead of the battery?
© 2026 MH Sub I, LLC dba Internet Brands
