Why must brake fluid on bikes be changed?
Old Jul 14, 2014 | 10:29 AM
EasTexUltra12's Avatar
EasTexUltra12
Originally Posted by Talldog
You leave the lid off, you have to keep adding fluid as you drain out the old. If you let the Master Cylinder run dry, you'll get air in the system and have to start all over again.
My bike is three years old and I re-used the gasket, but probably not a bad idea to replace with a new one.
Get yourself one of these, makes the job very easy.
Amazon.com: Mityvac MV8000 Automotive Test and Bleeding Kit: Automotive
If you can get a helper to add fluid as you drain the old, makes things easier also.
Buy a Service Manual for your bike, will save lots of money and headache in the long run.
Thanks for the Amazon link. I was going to go with speed bleeders but I'll give this a look.
got a service manual. Sometimes they assume a level of competence that is above my head.
David
Old Jul 14, 2014 | 11:03 AM
tfi racing's Avatar
tfi racing
I wouldn't leave the lid off while bleeding, a good chance brake fluid will splash out of the reservoir and land on your paint.
Old Jul 14, 2014 | 11:35 AM
CarrollB's Avatar
CarrollB
Not to hijack the thread but the manual says you need the special diagnostic tech tool or something they call it if you have ABS. As long as you never let the reservoir run dry so that you get air in the lines and don't turn on the ignition switch, is this special tool really required for bikes with ABS? I think I will simplify the job and order the speed bleeders before I start.
Old Jul 14, 2014 | 01:05 PM
TWIN CAM 96's Avatar
TWIN CAM 96
If you use the Mity-Vac it sucks the fluid out of the reservoir at the caliper & as long as you don't let the fluid run low you don't need to pump the pedal.
Old Jul 14, 2014 | 03:06 PM
$tonecold's Avatar
$tonecold
Get one of these from Harbor Freight, they make it really easy, but you do need a compressor. Item #92924
Old Jul 14, 2014 | 04:23 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
One of the most effective brake fluid change tools ever made. Eschewed by many because it's not expensive enough.
foxtrapper's Avatar
foxtrapper
Old Jul 14, 2014 | 04:33 PM
voodoodrug's Avatar
voodoodrug
I agree with the next post
Old Jul 14, 2014 | 04:39 PM
voodoodrug's Avatar
voodoodrug
they dont,seen cars go decades just fine with out changeing, were all just paroniod freaks.
Old Jul 14, 2014 | 04:43 PM
dochawken's Avatar
dochawken
Originally Posted by Lowcountry Joe
I prefer the simple route and installed speed bleeders. No extra help necessary with these things. You can do the job yourself. They disallow air from being sucked back into the nipple on the caliper when you let go of the lever. They eliminate the need to loosen-squeeze-tighten-release-fill-loosen-squeeze-tighten-release-fill, etc.,etc.
With the speed bleeders, all you do is loosen them 1/4 of a turn, then start pumping brake fluid through your reservoir until it turns clear down at the caliper nipple. Turn a quarter turn to cut them off and you are done. You will need three speed bleeders for a touring bike if you go this route.
http://www.speedbleeder.com/
They are really remarkably effective..so simple...but what a time saver. Installed one in my new hydr clutch build for my Fat Boy...
