Metzeler 23 front tire
Has anyone had a problem with metzeler new 23 inch tire. We put tire on two road glides now bikes handle bars shakes at low speeds.
I have had that happen. I had put on a new 21" on my old wide glide that I had. Was fine at speed but started to wobble around 20 mph when slowing down. It was a bad tire. The sidewall varied in thickness. If you run your fingers along the inside and your thumb on the outside you could actually feel the difference. Hope this helps.
Thanks I'm going to check it out.
© 2024 MH Sub I, LLC dba Internet Brands
