Touring Pullback Handlebars Installed
Old Apr 6, 2007 | 10:21 PM
Easyglide's Avatar
Easyglide
Default RE: Touring Pullback Handlebars Installed
ORIGINAL: dchoran
I had the touring pullback bars installed with all new extended/braided cables a couple weeks ago on my '05 Ultra.
$440. Very very pricey but worth every buck!!!
Much more comfortable position. GO FOR IT - you'll like 'em.
I would have preferred the braided cables--why they are not yet available for the 07's is beyond me. Was able to get the braided brake cable though. I may could have gone withaftermarket braided cables I suspect,but I did not want any issues with fitment.
Old Apr 6, 2007 | 10:44 PM
lp's Avatar
lp
I just did this install yesterday. I was able to keep all the same cables.
Now I did have to work the brake line a bunch (and I probably need to replace it one day) and had to re-route the clutch cable but its still in the fairing.
Bottom line, 40 bucks for the bars, spent nothing else....
I usually do the chubby bars, and do the internal wiring and all, but it's kinda a waste with an SG...IMHO. No offense to those that went that way.
lp
ORIGINAL: Radman51
"Easy"...........When you got the pullbacks installed, you had to lengthen the cables, right? I checked on this one time and my stealer suggested I go with braided cables since they had to be replaced anyway. Bottom line was that for a set of $50 bars, had to spend another $550 in parts and labor to install the bars and the braided cables. Thanks...........Radman
Old Apr 6, 2007 | 10:57 PM
shortleg's Avatar
shortleg
My dealer in rockville maryland got me a set made for everything for about
290.00 for SS.They are real nice.
Shortleg[Dave]
Old Apr 6, 2007 | 11:15 PM
Rollon's Avatar
Rollon
I had it done too with the SS braid cables on the brake lines. I like it for riding. But, the draw back is that it makes the bike harder to push around. The higher bars move the push point up higher. Cost about $600 with cables and labor.
Old Apr 7, 2007 | 08:36 PM
LockNut's Avatar
LockNut
shortleg, which dealer in Rockville? I installed the pullback bars and used the existing cables because I didn't want to buy them twice (once for the standard and again once the ss are out).
Old Apr 7, 2007 | 09:46 PM
shortleg's Avatar
shortleg
Dealer on Airpark road,should be rockville Harley.
Shortleg[Dave]
Old Apr 7, 2007 | 10:01 PM
Fireman44's Avatar
Fireman44
I did it on my 02 EG Kept the clutch and brake changed the other ones. If you live in cold weather area I would recomend heated grips. I had to make the wires longer but well worth the effort.
Old Apr 7, 2007 | 10:05 PM
Doc's Avatar
Doc
My Harley-Davidson dealer did mine here in KY and didn't change out any cables or brake lines. 40 for the bars and 3 hours labor.
Gone Bush
2014-2024 Touring Models
13
Oct 2, 2014 10:25 AM
nirschl
Jul 21, 2013 08:24 PM
avcaruso
May 14, 2013 08:38 PM
iride66
Jan 27, 2013 11:46 AM
roadking 3239
May 8, 2009 05:55 PM
