Mark this thread as Unsold
Garage Sale
Garage Sale
Lots of parts need to be sold. All parts are used with varying lengths of time and were on my 2010 FLKTK. Prices are listed plus the ride. Please PM me if interested and have questions. Not all pics are posted so please ask. Please due your own due diligence for fitment. Thanks for looking.
On bike when purchased. Unsure of manufacturer.
Married to current bike
Easy Pull Clutch Kit - used 1x26-044$15.00Dk Thunder Torque Inserts - used 1x118W$10.00Barnett Heavy Clutch Spring - used502-0001008$15.00Kuryakyn Accessory Clutch/Brake Purch Mount - used1698$45.00HD Shock Pump - used54630-03A$25.00Rear Fender Tip Light - new 59672-09A$45.00Mid Frame Air Deflector - used61400028$40.002 Yellow Lenses 3" - new$3.00Front Auxilary Ligh Bulbs 2 - used 68000056$10.00Head Light Bulb - used68329-03$5.00Stock Cams - used 24608-07A$25.0025590-07AStock Cam Sprocket - used25673-06$5.00Stock Transmission Sprocket - used40659-06$25.00Stock Pushrods - used17922-99$10.00 17923-99Stock Header no CAT w/ Shields - used66855-10A$100.00Stock Clutch Spring - used37871-04$5.00Stock Belt 140T 1" - used 40024-09A$50.00Stock Slipon - Re-cored w/1.75"65538-09$50.0065846-10AAfter market Slipons - 2.5" core - not sure of manufacturer$50.002 K&N Oil Filters - new171C$20.00HD Cover Black - used 5x93100026$100.00Dyno Jet Tuner - usedPV-1$175.00IMC Full Face Helmet Headset - used 1xHS-H110P$40.00IMC Half Helmet Headset - used 1xHS-H140P$40.00Heartland Transmission Mainshaft Bearing Inner Race Installer - used 1xTMBI-B26$25.00Heartland Inner Cam Bearing Puller / Installer TC 96,103,110 - used 1xICBLDNA-B15 + ICBPDNA-B16$75.00Antenna - CB - used 76319-08$5.00Antenna - AM/FM - used 76503-08$5.00
- Easy Pull Clutch Kit - used 1x26-044$15.00
- Dk Thunder Torque Inserts - used 1x118W$10.00
- •Barnett Heavy Clutch Spring - used502-0001008$15.00
- Kuryakyn Accessory Clutch/Brake Purch Mount - used1698$45.00
- HD Shock Pump - used54630-03A$25.00 •Rear Fender Tip Light - new 59672-09A$45.00
- Mid Frame Air Deflector - used61400028$40.00 •2 Yellow Lenses 3" - new$3.00
- Front Auxilary Ligh Bulbs 2 - used 68000056$10.00
- Head Light Bulb - used68329-03$5.00
- Stock Cams - used 24608-07A$25.00
- 25590-07AStock Cam Sprocket - used25673-06$5.00
- Stock Transmission Sprocket - used40659-06$25.00
- Stock Pushrods - used17922-99$10.00
- 17923-99Stock Header no CAT w/ Shields - used66855-10A$100.00
- Stock Clutch Spring - used37871-04$5.00
- Stock Belt 140T 1" - used 40024-09A$50.00
- Stock Slipon - Re-cored w/1.75"65538-09$50.00
- 65846-10AAfter market Slipons - 2.5" core - not sure of manufacturer$50.00
- 2 K&N Oil Filters - new171C$20.00
- HD Cover Black - used 5x93100026$100.00
- Dyno Jet Tuner - usedPV-1$175.00
- IMC Full Face Helmet Headset - used 1xHS-H110P$40.00
- IMC Half Helmet Headset - used 1xHS-H140P$40.00
- Heartland Transmission Mainshaft Bearing Inner Race Installer - used 1xTMBI-B26$25.00
- Heartland Inner Cam Bearing Puller / Installer TC 96,103,110 - used 1xICBLDNA-B15 + ICBPDNA-B16$75.00
- Antenna - CB - used 76319-08$5.00
- Antenna - AM/FM - used 76503-08$5.00
slyedog
08-21-2014 09:56 AM
