44MM Screaming Eagle Carburetor and Intake Manifold
I have the following for sale
P/N: 27932-99 C. SCREAMIN’ EAGLE BIG BORE 44MM CV CARBURETOR KIT
This carb kit is exclusive to Screamin’ Eagle. The CV (constant velocity) design creates smooth air/fuel delivery for exceptional low- and mid-range
power. The big 44mm bore allows this carb to feed even the most air hungry engine at high rpms. Easy to install with stock cables. Screamin’ Eagle Intake
Manifold P/N 29635-99 required for proper fitment on Twin Cam 88-equipped models. P/N 29636-99 required for Evolution 1340-equipped models, and
P/N 27643-00 required or XL models. This 44mm CV carburetor is not cruise-control compatible. For race application only.
Fits ’90-later Evolution 1340-equipped models, ’99-later Twin Cam 88-equipped models, and ’88-later XL models.
P/N: 29637-99 HD 44MM SCREAMIN’ EAGLE BIG BORE INTAKE MANIFOLD
This intake manifold is required for use with the Screamin’ Eagle 44mm CV and 45mm Flatslide Carburettors. Can also be used with 42mm Flatslide or
your stock CV carburettor. For race application only.
Fits ’99-later Twin Cam 88-equipped models.
These were installed on my 2002 Electra Glide Classic when i bought it. I have since changed to a different carburetor. The 44MM does have the sportster throttle cable bracket. If using this on a Big Twin you will need the correct throttle cable bracket. I just replaced the accelerator pump diaphragm and gave the carb a good cleaning. All other parts look good. The idle jet is 48 and main is 220. It has the stock needle but I did not write down the needle number. I can get it if you like.
Will also include the digital installation instructions for the 44MM carb.
$150 Shipped.
Thanks
Justin
$150 Shipped.
Thanks
Justin
eglideic
Touring Parts
04-25-2020 08:04 PM
hawkyou
01-26-2010 05:39 PM
ilmanzo31
03-28-2008 08:46 AM
