Inexpensive Tank lift and floorboard extension
/ˈkäpēˌrīt/
noun
noun: copyright; plural noun: copyrights
1. the exclusive legal right, given to an originator or an assignee to print, publish, perform, film, or record literary, artistic, or musical material, and to authorize others to do the same.
Fuzzy, I feel that you have confused a copyright with a patent. Since the common nuts and bolts I used to perform a similar task look nothing like the kits offered by other vendors there is no copyright or patent infringement.
I was just ,making a point that the idea was pirated .... not one of us would of come up with the idea of lifting a tank or moving the floorboards out, unless someone else had marketed the product. Just my $0.02 worth. No different than illegally downloading songs. The idea is what was stolen ... again ... just my $0.02 worth. I'm guessing if the op had a patented "widget", and I came to the forum and told people how I made my own widget for a fraction of the price, he would probably feel a little different.
I sure am glad someone built the second & third brand motorcycle after someone decided to put an engine on a bicycle.....
Just Sayin...............
Tryker Dude,,, Keep on enjoying your skills at crafting all the mods & parts you can for yourself ! Just make sure your parts are safe for the purpose you intended them for.
Always great to see a little ingenuity !
The song is ... but then I didn't pirate the song.
I just want my seat front moved up a squinch.
"...not one of us would of come up with the idea of lifting a tank or moving the floorboards out" Don't think that's true, if there is a need for something a lot of folks are capable of thinking of stuff like that.
I knew as soon as I first sat on a trike at a dealer that I would have to do something like moving the floorboards out. And extending the width of the brake pedal and front shifter peg. My feet point outwards and my shin was hitting the air cleaner, hard to reach the peg on the other side. Fortunately parts were available to do the first two, and were more "elegant" than anything I would have come up with. But I like my solution for the shift peg more than most commercial options.
I don't know if everyone knows about this thread, but it started out for Dyna's. After a while it changed to most all models. Great ideas & you can adapt lots of them to whatever.
https://www.hdforums.com/forum/dyna-...fifty-bux.html
Lots of reading ! Many you can't use, but might use the idea.
