Wiring a tg for love juggs fans
I'd like to buy a set of Love Juggs fans for my 2014 TG but I'm confused about the wiring. Love Juggs has an 8 pin plug and play adapter cable assembly for 2014 and up Harleys, but I don't know where they can plug it into. I have a plug under my seat that I have a Road Zepplin connected to. There is also a plug under the left side cover(not being used) but it is a 6 pin plug.
Love Juggs will install for $75..... And since I don't like the way electricity "bites", I'm leaning toward having them do the job. I have been known for screwing up things that can't be screwed up.
I don't have a heating problem personally, but keeping the engine cooler is a good thing.
Any one have any insight or ideas??
Didn't you also have to buy the Love Juggs(LJ) 8 pin adaptor to go from Harleys 4 pin plug to the LJ 8 pin plug?
I wasn't reading to comprehend I guess. I see yours is a 14 my. Mine is a 12my. Mine has a 4 pin already if memory serves me correctly. Its been awhile since I had that connector apart. I do know I only had to purchase the Y harness, no other adapters. You 14 my is the CANBUS system thou, newer, in many ways better, and often with different connectors.
Ken
Ken
I also have 2014 TG with LoveJuggs and Road Zepp seat. The connector on the left side is P&A J4. I installed the Dash Panel Kit 71400106 (79.99) and the Dual Harness accy 70264-94A (19.99). There are three switches on the left side. On stock trike only Switch 1 is used for the Aux Lights. This kit will give you Switch 2 (under 2amps) and Switch 3 (relay for over 2 amps). This way I turn both the seat and the fans on from the dash.
papapuskit
02-11-2008 02:08 PM
