J&S Trike Jacks
Update on Jack
I never did update my purchase in this thread. I have recently had several inquiries about the "new" style J&S trike jack and it's use with the DK Custom Oil Filter/Cooler relocation kit. The new model jack works fine but to enable it to work safely with the 17 models, as well as previous model years, they had to re-design it a little. The new jack is made to be placed under the frame from the left side of the trike.... not the right side like the older models. It works fine, you just have to make sure you get it back enough to clear the crossover transmission mount nut on the right side as the jack comes up.
The picture enclosed shows that the filter re-locator kit is well above frame level. The tape sitting on the floor is touching the bottom of the frame rail where it starts to curve upward.
As usual, this is my experience and I can't guarantee it will be your experience. However I have not heard of any clearance problems with the kit or the jack.
The "new" 2017 J&S jack works without drama on my 2017 Tri Glide Ultra. You can now even polish the inside of the rear wheels if you so desire. When I got mine, I thought, hey, that might be kind of fun. I even included a picture of the inside of the rear wheels. I know, kind of lame, but it was a nice day and I had some time to just fool around.
OTOH, it makes quick work out of changing tires or doing other things like oil changes, etc. underneath the trike.
J&S Jack With DK Custom Products Oil Filter Relo on 2017
Here are a couple of pictures of using the J&S Jack with the DK Custom Products oil filter relocation kit. The difference between my jack and "s060's" jack is that his is air and mine in mechanical. The mechanical jack was almost a problem with this combination, but for the first time in 68 years, it appears I got lucky. The first picture shows the oil filter attached to a bracket and while it appears low on the 2017, the filter is above the bend in the frame, as described by "so60". The problem I had (have) is that the forward part of the foot pump lever would come into contact with the filter if the foot pedal were pressed all the way down (picture 2 below). I am limited to about one-half inch strokes until I get some height on the bike. It works (picture 3), but bottom line is you have to be careful with the manual J&S Jack when you have the DK Custom Products oil filter relocation kit installed on a 2017.
Trike Lift
Good pictures John. One thing I will add to this, the "riser" on the rear arm is naturally what you have to watch out for while setting up to lift the Trike. I slide it under the Trike to where the riser is just maybe a half inch to 1 inch past the drive belt. At this point the jack is back pretty close to the rear wheel. I then go to the other side and see where it looks like the riser is going to hit. I just make sure the side of the riser is at least a 1/4 inch behind the nut holding the crossover pipe mount (on my 2016) and appears to be lined up straight. I then start easing the jack up and keep an eye on the riser alignment and the crossover mount nut and mount. I bought the air model and I am glad I did. Arthritis in knees makes it tough without it.
I also ordered one with the 5% vet discount. Took 2 weeks to ship it due to a backordered part. Works great. First time I let it down one of the safety arms fell back into position. Bent it in a u shape before I found the problem. Called and told them the problem and that it was my fault. They sent me a new one no charge. Thanks J&S
Your Experience Was Better Than Mine
(ADDED AS EDIT)
Although, let me say that I did request the veteran discount AFTER they originally charged my card, and they said that they would honor that (and they did), and they had a sales promotion for free shipping, and they refunded me the amount of the freight, after placing the order, so they did do some things right! (Besides manufacturing an excellent product)
Last edited by HOGN IT; 04-07-2017 at 10:37 AM. Reason: Adding exception to my post
