Left Rear Leak
I just found yesterday something leaking from the area behind my left rear wheel. Getting ready for a 2 week work trip so I haven't been able to get it on a lift and investigate.
It's not much, but it is a leak. Never seen it before and we just returned from a week long 1100 mile trip 2 weeks ago. What's leaking, by look, feel and smell, is something like a clear oil. My first thought was brake fluid but it doesn't look, smell or feel like brake fluid. I don't see anything on the tire so it has to be inboard but not by much. What's in that area that could be leaking on a '14 TG? Anyone know? If not, I'll try to investigate the service manual while traveling for work over the next couple of weeks. TIA, Lilman |
Could be a bad shock.
Have you checked to see if your shocks are holding air? If they are holding air, I don't see it coming from the shocks. I don't know what to tell you, if it's a brake line, other than get it to a dealership.
Bubba |
Within 1 week of bringing my 2016 home, I had the same exact issue on the right side. The tech could not find a problem with the shock initially and they both held air. When he removed the right shock at my insistence (I had a picture of the puddle of clear oil as proof) he discovered the shock was, indeed leaking. He ended up replacing both sides, because the left was leaking, too.
What you describe sounds like a shock that has leaked oil, to me. |
The only oil back there is in the shocks or the brake lines. Clear oil that is odorless makes me think it is a shock absorber.
Originally Posted by LS Bob
(Post 16104712)
What you describe sounds like a shock that has leaked oil, to me. Thanks, Bubba |
Hadn't even thought about the shocks! They were holding air when I left for Daytona, haven't checked since.
I need to get it up on the lift and get the tire off so I can see better. That may have to wait until I'm back from this work trip. Regardless of what it is, I will be fixing it. Warranty is gone and I do all my own work, on everything except my company car and wife's Fusion. I really don't think it's brake fluid unless the rear has something different than normal braking systems. Too thick and with no smell. It may be a shock, when I think about the fluid, it is close consistency to fork oil. Maybe it is a shock, I've been looking for a good reason to get rid of the air shocks anyway! |
I'm think of SuperShox as a replacement for my air shocks
Not trying to be a smart ass, but check your tour pack and trunk for liquids that could have spilled. Ask me why I know this.
Gitarded, that's the very first thing I did! When we travel, there's no telling what the wife may stick in there!
© 2024 MH Sub I, LLC dba Internet Brands
