first trike ride
Received 3,940 Likes
When I made the move to 3 wheels I hated the turning. It was so much work and I didn't like the at speed squirrelly feeling. I don't know what I did to compensate except keep riding it. Now it feels so planted to the road and the turns are the best part ! I can run circles around the two wheeled riders and it is just a blast. The wife goes with me now before I had to talk her into going now she asks me to go. I love it and the wife must feel better on the back of this compared to two wheels.
Keep riding it it will fall into place eventually
Hap
Hap
Fearless (old nickname) (04-18-2017)
RElax and enjoy. Three pieces of advice.....never put your feet down cuz the back tires will climb right up your heels..# 2...DO NOT LEAN TO TURN..u can lead til your elbows bleed. IT WILL STILL GO STRAIGHT ! and # 3..when gassing up be aware that the posts in front of the pumps are closer than they used to be and an ugly yellow scrape on your fender will not be pretty,.
Prior to purchasing my '18 Tri-Glide in August, '18. I had 49+ years of riding motorcycles but NEVER on a trike!
I had however, rode a three-wheeled ATV and had owned and rode snowmobiles many, many miles, both of which had proved to be very similar to riding the trike.
Knee against against the fuel tank (inside) with your foot pushing against the (outside) floorboard in turns and "leaning-in" towards the curve makes for curves much easier to negotiate!
After 3 seasons, one 6 thousand mile trip and a total of more than 10,000 miles on the odometer I have found the following (IMHO):
1. Trikes use more gas than bikes
2. Trikes can easily find more bumps than bikes
3. Trikes require more effort to steer in curves and are more tiring to ride than bikes
4. Trikes provide more stability and removes the insecurity of riding on wet or unstable surfaces and tipping over in slow turns or when stopping
I remember the 3 wheel ATV from farm days...they wud tip over backwards if u rode over a cob... Trikes find more bumps because u have 3 tires and the back 2 are double the width of a 2 wheeler...I think leaning is more a habit than effectively helping turn but Ill try it. Mileage is not as good because the load may be twice that of a 2 wheeler. Soften up the bumps by never riding in Illinois.
Peter Kelly (12-27-2020)
THe ride can be improved by lowering the rear tire PSI down to 22lbs if you're riding solo but I ran 24 in mine when loaded for a trip.
My friend (who has a ton of metal in his body) regretted buying his '16 Tri-Glide (due to the rough ride over bumps) until I convinced him to get the DK lift kit and shocks. He's now a "happy camper"!
Since I had talked him into buying the lift kit and shocks I ordered the same and had it installed on my '18 before I really had put many miles on it so I can't be sure of the ride but I do think it helped the handing in curves. If I lived in an aea where I did a lot of riding on curvy roads I think I'd play with the front tire PSI in order to see it slightly lowering it would help the handling in curves. A late friend of mine had road his trike for years and he told me that he had his front wheel to "push out" on curves if he tried to take a curve too fast on wet pavement. I've yet to experience that but I tend not to push any bike too hard on wet pavement.
BTW, Ilinois roads ain't got nutti' on Michigan roads!
for the guy w 117 2 wheeler.
You have the ideal setup to CONVERT to a trike..u have the power u will need and u can use someone like Hannigan w wider track, independent suspension and their factory can color match your current bike and get 3 wheels to match w PM wheels or other on line manufactures.
