2016 Tri Glide Classic an utility trailer
Boscowtx (04-13-2017)
Fearless (old nickname) (04-14-2017)
IF this is an open trailer with a full 5' opening, it should work but will be very tight. At least you can tie down standing outside the trailer. IF this is an enclosed trailer, it will not work since the actual door opening will be less than 5'. An enclosed with a ramp door will have the door cables that your fenders will not clear. I have a 6x10 v-nose, it works but is tight (about an inch & a half clearance on each side between the cables).
As was said above, tie it down so it can not shift when hitting road bumps. Good luck.
If the trailer is a 5'4" it can fit but it is tight. A lot of 5 ft. trailers are 5' 4". I have hauled my 15 TG on one. Check the width on the tightest part, probably where the latches for the tailgate are. The one I use is 60" leaving 3" on each side. You can't believe how tight 3" is when you back it off the ramp.
Boscowtx (04-18-2017)
800XC SP
13
03-05-2011 06:23 PM
