Progressive Shocks / Installation Question
I am in the progress of replacing the OEM shocks on my TG with a set of 444-4020 Progressives. I read on the installation instructions that they can be installed with the adjustment ring on either the top or bottom and of course adjustment will be much easier with it on the bottom.
My question to those that have installed these shocks "upside down", have you had any issues that could be attributed to the installation?
Given that the majority of users of this model of shocks have done the pre adjustment of 3 rings, it is highly unlikely that I will have to adjust after installation, but just in case.....
Appreciate any feed back...
Such a situation here north of 60* - too cold to work on the trike in the garage in the winter and then when it's a good temperature to work, I should be riding!!
Cheers
Doug
Cheers
Doug
8Crow, I installed mine upside down. 3 1/2 turns of pre-load. I tried 3 and it wasn't too bad, but I like 3 1/2 better. I weigh 235 lbs. No issues. Use the spacers they give you for side to side alignment. I needed them.
I also have the tglidestuff 2-hole lifts. Working with forward and rearward mount locations. I think I may go back to 3 turns of preload when I put the shocks back in the forward (normal) hole location.
Looking forward to the first ride to see the difference. Lots of pot holes in my location so should be a good test!!
Cheers
Doug
Not sure if the FW is much different than the TG as far as the rear body work but if you have the clearance to work at the upper mount, it is doable...
Good luck...
Doug
Thanks to all that provided feed back regarding the Progressive installation.
I finished the install as well as polishing up my wheels mounted with new Michelin Defenders before putting them back on the TG. Also have the polished SS discs behind the wheels now so looks great! Also removed that useless piece of crap of a park brake while she was up in the air. Replaced it with a Velcro strap on the front brake - more efficient, a lot lighter and easier to adjust.
Went for a good ride this afternoon and my bride was very impressed with the improved ride quality!! It'll never be a Cadillac ride but it sure is a vast improvement over stock, especially on the back roads here in New Brunswick... Not likely up to the ride quality of a couple of other brands that are popular here on the forum but then again they weren't near as spendy either.
Another riding season is officially under way here in the North country!!
Cheers
Doug
Cheers
Doug
