Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri Glide electric reverse locked up. Big amp draw when engaged.
Old 04-15-2017, 11:50 AM
daviddeel's Avatar
daviddeel
daviddeel is offline
6th Gear
Default Tri Glide electric reverse locked up. Big amp draw when engaged.
Everything looks to be in working order on the motor. Brushes look great. can turn gear box when armatuer is separated but when I assemble it together and install it's just a dead draw on the volt meter when you activate. HELP
Old 04-15-2017, 11:57 AM
daviddeel's Avatar
daviddeel
6th Gear
Is there any HD mechanic's online that can help me out here !!!!?
Old 04-15-2017, 04:55 PM
Fearless (old nickname)'s Avatar
Fearless (old nickname) is offline
Default They are a huge draw on the battery
You should back up at 2000 rpm...reverse when my battery was bad it would kill my battery in a heart beat. I keep Old Shiney at 2000 rpm when I use reverse which is very seldom and never up hill. Just how I do it good luck Fred
P.S. I am not by any stretch not a Harley Technician
Old 04-15-2017, 05:22 PM
Cool Inferno's Avatar
Cool Inferno
Cool Inferno is offline
Not a tech here but if your battery is good with sufficient charge and engine running when you tested it, I would take the unit to an electro-mechanic shop and have them bench test it.
Fearless (old nickname) (04-15-2017)
Old 04-15-2017, 07:00 PM
daviddeel's Avatar
daviddeel
6th Gear
Thanks guys , this thing is really defeating me !!!
Old 04-15-2017, 07:01 PM
daviddeel's Avatar
daviddeel
6th Gear
How can you tell if the starter gearbox clutch is working properly ??
Old 04-15-2017, 07:49 PM
rhino 2's Avatar
rhino 2
rhino 2 is offline
Did you check the breaker, Right side panel... I had my reverse motor out [Its not a starter motor] And every time it was the brushes....Finely
i gave up and went with a mechanical reverse....
Old 04-16-2017, 08:46 AM
daviddeel's Avatar
daviddeel
6th Gear
Thanks Rhino 2 , The breaker is fine . Power goes to motor when engaged but it just drops amps on the volt meter. I'am thinking like you it probably is the armature or something dead grounded in the brushes !
Old 04-16-2017, 12:10 PM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,481 Likes on 1,540 Posts
have you checked the winding in the starter for being grounded with the case ? broken brushs ? lots of auto part places can bench test it.
Old 04-16-2017, 04:01 PM
daviddeel's Avatar
daviddeel
6th Gear
I took it apart and did a visual inspection , but I think I need to pull it again and have it bench tested like you suggested . Thanks hardheaded
Quick Reply: Tri Glide electric reverse locked up. Big amp draw when engaged.
