Removing 2016 Tri Glide stock exhaust
Want to install my new Rush Big Louie's. I have loosen the clamp that holds the muffler to the head pipe, but how do I remove it from the rear. I see a star head screw that appears to hold the metal bracket/rubber mount. Do I remove this screw and go from there? Any info will be greatly appreciated.
Received 3,939 Likes
These two bolts are what hold the rear of the muffler up and onto the trike frame.
Roadhog55 (04-25-2017)
This weekend, I installed the DK Custom Comfort and Lift plates and changed out my slip-ons. On the 2014, I couldn't get the axel low enough to line up the bolts on the plate so I disassembled the exhaust. First trying to drop the Z pipe; that didn't work so I had to drop the mufflers. I found it much easier to remove the trunk so I could access those two bolts holding the mufflers up (2 on each side). It only took about 20 minutes to get it off. There are just six 1/2" hex bolts inside the trunk, and two 5/16"X1" hex cap screws on each side under the side covers. That made it a whole lot easier. The DK product is amazing, but the directions really gloss over removing the short hex bolts holding the mufflers up. It was a b-atch to try and get to the bolts without removing the trunk. Removing the trunk to get at the mufflers is an extra step, but really a time saver in the long run.
