Tri Glide Stuff New Adjustable Lift Brackets Quick Review.
I have a 2009 tri glide and I have read about the great ride improvement and handling better on the tri glide with these kits. I must be missing something because I installed them and the only thing I can tell is that I have more ground clearance. I think they are over rated by a lots.
but the extra ground clearance does help.
ROLLER
ROLLER
Not to offend but I bet your one of those guys that still fight your trike and don't quite understand the push pull lean part of steering a trike. I have met a few over the years that don't completely get it down or understand it. The ones I have shown were so surprised at the diffrence in steering there trikes by changeing there riding/steering technique. Don't get me wrong trikes are what they are but a little technique goes a long way to improve steering with or without a lift installed. You have missed something because the lift kits do make the steering effort less and have on every trike I have installed them on. The extra ground clearance to me is a secondary plus from the lift brackets.
Again not to offend just what I have seen a few times over the years.
Ride Safe,
Bill G
HDDOC (07-17-2017)
I did position 1 for a little while, but went back to position 2 since I have a 2012 and no exhaust interference issues.
If you had a exhaust clearance issue, then you'd probably want to be using position 1 and the most rearward shock bolt hole. That should get you situated.
The following 2 users liked this post by iaff84:
Dante221 (12-17-2018),
Oogie Wa Wa (11-29-2018)
Bill G
14
11-27-2017 11:10 AM
choochoo1956
04-05-2017 11:53 AM
Bill G
03-20-2017 05:28 PM
