Tri Glide Stuff New Adjustable Lift Brackets Quick Review.
Let me start this review by saying I formerly used and tested the first version of these lift brackets the original 1-2 lift brackets on my 2017 Tri Glide. These brackets worked excellent and solved the issue with clearance between the weld on the exhaust header and the swing arm on the 2017 model Trikes. Many vendors at first concerning the clearance issue on the 2017 models dis missed the issue on them as a one off issues with only certain 2017 models. Tri Glide Stuff did not and started addressing this issue early on working with dealers and testers like myself with the issue. (I want to make clear I paid for these brackets because I needed them to solve my clearance issue and I was willing to test them no special favors were done here).
Now as time has went on other vendors are as well dealing with this issue offering simular ideas on lift brackets.
On to the new design adjustible lift brackets,
Dennis at Tri Glide Stuff has now come out with a new version of this lift bracket the adjustable lift bracket that offers two lift adjustments. A 1.2" lift as well as the 1.5" lift all in one bracket. This lift bracket allows the normal stock shock position and the more laid back (easy ride) shock position. You will see three shock positions on the brackets. In the 1.5" lift position for the stock shock placement you use the 1st hole towards the font of the trike as reference and for the easy ride shock position you use the middle hole. For the 1.2" lift position you use the middle hole for the stock shock position and the third hole towards the back of the trike for reference for the easy ride shock position.
These lift brackets are of excellent quality and fit all year trikes. They give you in one lift bracket design all the adjustability you could need to set up your trike just right for your needs. They also allow you to change your mind or your set up for fit reasons all in one lift bracket by design, very well thought out.
The install on my 2017 Tri Glide was a breeze and very easy to do. The adjustable lift brackets fit perfect.
The ride and steering was great. This did not surprise me at all because it has been proven time and time again what lift brackets do for Harley Trikes. There were no surprises here and the performance improvements were spot on.
So if your looking at lift options for your Tri Glide, keep these well made well thought out adjustable lift brackets in mind. The quality is top notch from the machine work to the fit and finish. It is my understanding at this point these brackets will be offered in a sweet red color the ones I tested were done in blue and they are staying on our trike.
Thank you to Dennis at Tri Glide Stuff for allowing me to test these brackets they worked great on our 2017 Tri Glide. They also look great in the blue test color that matches our blue Tri Glide very cool. The red would have matched our Pro Action shocks too but I really like the blue.
Just added update,
I just added a pic below of the red lift brackets on another trike from Tri Glide Stuff web page just to show the color. Note- in the pic the red lift brackets shown are in the second lift position the 1.5" lift with the shocks in the easy ride position.
Ride Safe everyone,
Bill G
Just added update,
Ride Safe everyone,
Bill G
Bob,
Pic's would be great.
These lift brackets are very well made (very heavy duty) great machine work and attention to detail in there design. I like the duel lift 6 bolt hole two position design 1.2" & 1.5" and the multi shock position option all in one bracket. After seeing these lift brackets and installing them I personaly like the fact they were not designed to pivot on the top bolt with only one shock position to get the extra lift out of the bracket.
Ride Safe,
Bill G
Bob,
Ride Safe,
Bill G
Ride Safe,
Bill G
Bill G (07-07-2017)
I decided to go with TGlide stuff lift brackets this time rather than the other available. I got to say Dennis was rocket fast on shipping. They mounted up with no issues since I followed his directions rather than winging it. Tried the rear shock layback position. All is well, getting ready for a 1200 mile round trip this week to Cincinnati.
Bill G (07-07-2017)
Great Job.
Bob that looks good, great job.
On the shock angle in theory the more relaxed position should allow the shock function to be more efficient. I have the Pro Action replacement rear shocks on our 2017 Tri Glide. The owner of Pro Action recommended in a phone conversation with me the more laid back or easy ride position to me over the stock shock position when mounting. He also stated or confirmed the information I stated in my first sentence concerning shock function and efficiency concerning the two diffrent shock angles.
Let me know if you notice a diffrence.
Ride Safe,
Bill G
Have a great time on your trip.
Ride Safe,
Bill G
llif kits
I have a 2009 tri glide and I have read about the great ride improvement and handling better on the tri glide with these kits. I must be missing something because I installed them and the only thing I can tell is that I have more ground clearance. I think they are over rated by a lots.
but the extra ground clearance does help.
ROLLER
ROLLER
