Backing Freewheeler up ramp
Has anyone backed a Freewheeler up an enclosed trailer ramp. Wondering if it has the power to do it. Looking for enclosed trailers to tow my StreetGlide and the wife's Freewheeler. Thinking about a 8 X12 backing the Freewheeler in then putting the StreetGlide in.
The "reverse" on the Harley Trikes is a backing assist. IF the ramp isn't too steep, and depending on the weight of the 'backer' you may not have a problem
BUT
Why not drive the trike in forward, and let gravity back you out. Load the 2 wheeler first
OR
you can use a come along to pull the trike in backwards
BUT
OR
I agree with Screwball and Bronxbill. the reverse is just a aid I still tend to park uphill and just use the reverse when necessary. Still push it out the garage. I have seen on here that those motors just have so many back ups on them. I would put the bike up first or have the trailer on a down hill.
I simply load any bike into the Van/enclosed trailer with a $60 2,500 lb capacity HF 12 volt winch. Easy peasey. Just sit on it and push the remote fob. Great with the garden tractor also.
In a trailer (two wheel) 60% of the load needs to be ahead of the axle line. 70% in a dual axle. Might be best to put the trike in first. The trike fits the Forest River 6'X12' enclosed trailer quite well.
If the load is too far to the back the trailer will weave side to side like an old Harley in a death wobble. Especially down hill and/or braking. Not fun at all.
Freewheeler Backup
I have not tried it personally but since your reverse is the starter motor, and with the shear amount of torque you can put out with these DC motors I would be shocked if it could not.
That said, why put the wear and tear on the starter, I second the drive it in forward, and let gravity roll you out if you can.
Just going off of what the Harley manual for my 2015 said, or at least what my feeble mind read whatever the voices in my head tell me at the moment
