Garage Smells Like Gas
I have a 14 TG and now after riding it and parking in the garage the garage smells like gas. I have to leave the doors open for a while to air it out. It didn't do this the first 2 and half years I've had it. It started this late last summer. Anyone else have this experience and what may be the cause and cure?
Months before this started I installed some different slip on mufflers, stage one air breather and a V&H FP3. I thought it was the tune because I have made changes over the 2 summers I've had it but as a test I temporarily flashed it back to the stock tune which should make it run very lean and I still get the smell. The bike runs fine and I don't smell this while riding. Only in the garage after riding.
I have an 11TG, mine does this once maybe twice during the summer especially when the temperature is Hot outside. The pressure builds up in the tank and burps air out of the overfill tube. You should not be to concerned unless you are actually leaking gas from a leaking line or you have filled the tank to full.
The following 2 users liked this post by Oogie Wa Wa:
5wheels (09-19-2017),
Muffbrorick (09-12-2017)
