Issue with Love Jugs -Any suggestions?
I recently purchased the Cool Master system and had it installed on my Tri Glide. At first the system was installed 3 inches away from the cylinder heads then was repositioned to be about 2 1/4 inches away. An issue has cropped up that I don't consider trivial. I've been riding recently in temps ranging from 72-76 degrees.
After about 20 minutes of riding my right calf is very hot. I know the Tri Glide engine is very hot and what is happening is that the Cool Master is pushing the hot air through to the right side of the bike. The air stream impacts my leg at the calf. And its hot. Very hot.
I'm used to riding big bikes with hot engines. My last big cruiser was the 2053 CC Vulcan.
So far I have been trying to avoid that stream by sliding my right foot forward. But that does not place my right foot in the best position for a quick stop.
I am going to speak to a local bike mechanic/fabricator about the possibility of constructing some type of ceramic shield (like an extension of the partial shield that comes stock) that would both protect my right leg and maybe flow some air on the right side to the rear cylinder head.
I would assume this problem is most prevalent on the Tri Glide with its super hot engine. Would appreciate any suggestions.
PS I know the product has an excellent reputation and is very well made. But my right calf needs some relief
I would prefer not to remove them and would appreciate any suggestions.
Thanks
Gerry
Thanks
Gerry
Thanks
Gerry
Thanks
Gerry
Hmmm.
I haven't read the install instructions for the love jugs, but is 2 1/2 to 3 inches out from the heads the normal mounting distance? Seems like that is too far out. My Ward FCS fans are about 3/8 inch from the fins and right side heat is no problem except in very heavy slow or stopped traffic. Like the Man said, call him. I am sure they can help you.
"For every action force there is an equal (in size) and opposite (in direction) reaction force. Forces always come in pairs - known as "action-reaction force pairs." Newton's 3rd law of Physics. You turned your Harley from a radiant oven to a convection oven. Temperature may drop a few degrees with the fans, but going from 300* (normal head temps) to 260* won't feel any different on your leg. It is the curse of high cubic inch, air cooled motors.
Part of the problem comes from actually moving too much air fast enough to be hot when it gets to the leg. The old argument about the smaller fans vs large fans.
The smaller fans put the air where it does the most good.
The larger fans are blowing air from more of the cylinders. Also picking a lot of the hot air from the left side that normally would have blown away on that side & puts it through to the right side. This puts more air out the right side. Most times the smaller fans do a better job of cooling the oil than the larger fans.
This is because of where the air is concentrated. Mostly at the upper & lower parts of the head & a small area of upper cylinder. This is where most of the heat is created.
I have the smaller fans (Wards) & in traffic I get some hot air, but it goes away when I get to moving.
Fearless (old nickname) (09-21-2017)
Thanks
Gerry
Thanks
Gerry
When she would complain about the heat, I would point out that that was the Jugs working and to suck it up.
I never considered the Jugs to be a creature comfort device. But if it is cooking you that bad, I might re-consider.
Received 3,940 Likes
Thanks
Gerry
Thanks
Gerry
Talk to Steve at LJ, that should help, but there are also a lot of little things you can do that will, collectively, cool it down substantially.
You can see a Report on how to cool it down HERE.
