rear end shifted
Received 3,940 Likes
Wiki: "A Panhard rod (also called Panhard bar or track bar) is a suspension link that provides lateral location of the axle. Originally invented by the Panhard automobile company of France in the early twentieth century, this device has been widely used ever since."
Simplified drawing, not trike specific.
Apparently it does keep the axle centered, but if it was totally detached the trike would violently waddle side to side all the time. And I can't imagine it getting bent, unless he really whacked the rear end up against a curb hard at speed or something on the right side.
Perhaps I am staring right at it, and just don't see it.
I do understand how a pan hard rod, used in a traditional manner on a car or truck will help keep the axle centered....but looking at the diagram below of the PHR on the Tri-Glide, I'm just not seeing out it would keep the axle centered.
Willing to learn, help me out please.
Kevin
Kevin
Kevin
Snap #4 or #6 and the rear axle can shift left or right freely.
The panhard bar attaches to the frame on the left upright #4. It then connects to the rear axle at #7 in the picture with bolt #6 and washer #5. The shock mounts just hold the rear end in the up and down position. The panhard bar keeps the rear end from moving left to right while the suspension is in its up and down travel.
The axle is connected to the swingarm, and the swingarm to the frame. So how can the swingarm/axle move left or right more than the few mm allowed by the swingarm pivot?
Kevin
The panhard bar is a solid mount with bearings to allow the movement up and down with minimal side to side movement.
While all the other mountings for the whole rear frame assembly is rubber mounted or mounted with bearings that can and will allow movement sideways if not for the panhard bar to guide it.
Take one end of the bar loose on your Tri and see just how far the rear frame can move. You must allow for any worn bushings like the swing arm also. The more wear in all other places are mostly hidden by the panhard bar. In the case of a newer trike the lesser the side movement.
This is why if the panhard bar brgs. are worn out the Trike will try and dart from side to side, or try to follow the high side of a highway.
Thanks guys...the light came on! doh I was looking right at it the whole time, and just not seeing it.
I see how a even few mm movement at the swing arm pivot could translate into more movement at the axle, absent the PHR keeping it centered with the frame that the body is mounted to (and that one end of the PHR is mounted to).
Kevin
Kevin
Kevin
Kevin
The swingarm (aka rear fork) is built more to keep the axle from moving forward and backwards with acceleration and braking, but lets each side shock move up and down more or less independently because of the thick rubber mounts. Not designed for side force, though. Each suspension piece usually handles forces primarily in only one or two directions.
we were leaving yesterday and a friend who has a 13 tri was with us. we stopped at the local gas station when someone in our group noticed the rear axle was shifted over to the left in his trike. the tire was almost touching the inside of the fender. he was pissed and took it home, so we didn't get to check it out much. but i'm thinking the panhard bar ends must be bad. what do you guys think ?
Kevin
