'17 Tri Glide parking brake trouble.
Parking brake has always been about 7 clicks down, when applied. Should be about 4/5 clicks. I cannot move the adjuster ( long nut) at the front end of the cable, the one with the jam nut. As far as I can tell, that is the only way to adjust the parking brake. Any advise will help, thanks.
I finally got it adjusted. Why someone would apply loctite to the threads, is beyond me, but they did. I had to use some heat to get it to turn loose, then adjusted as it needed,for 4 clicks. Works fine now. I also added some marine grease to the threads, before locking it down, and replacing the rubber boot.
Geezer Glide Rider
13
09-23-2015 11:28 PM
Boom
05-04-2011 03:01 AM
