Anyone install a back rest on their TG? BOUGHT factory mount and wonder about install
I applied the tape in the area indicated. I suppose it does keep the metal parts from rubbing a hole in the seat. However, mine only "half-stuck". It is very thick/rigid tape. Half of it has worked itself away from the seat. Fortunately it is below the level of the top of the seat and doesn't bother the passenger.
When the rest pivots forward the edge of the mount tries to dig into the slot in the seat.
I purchased extra pads as they get lost due to hot weather and moving the backrest. Been thinking of using a better glue than what comes on it.
By the way,,,, the adjustable mount has to be shortened to work with the Hammock seat. The latch sits too high and the rest frame has to be cut back 1".
There is a good tutorial on the forum about doing that.
Great info thanks
All I do is find out where the mount hits the seat and how far it comes into the seat and place the pad accordingly. Simple once you look at it.
leblanc1
04-24-2013 10:25 AM
