Upon relocating oil filter
does the passenger experience more heat, due to the location of the oil filter? Since the new oil filter location is under the left footboard, when stopped, does enough heat rise for the passenger to notice?
I am considering relocating the oil filter on my FreeWheeler but this question needs to be answered before I do any work.
Received 3,931 Likes
If you are doing the Oil Filter/Oil Cooler kit combo...everything is much cooler (30+ degrees cooler), and that is very noticeably cooler.
Even with just the Oil Filter Relocation, everything is 10 degrees cooler...so that is all the air going past the engine and flowing up the passengers sides is cooler, with the combo kit, and with just the filter relo.
If any of our Customers have thought that it felt warmer, none of them have mentioned it to us...but we have had many mention that it felt cooler.
DK Custom - ST (11-15-2017)
That relocation kit will probably not fit our trike as the Hannigan body looks to be in the way. So, I plan to go with the universal oil filter relocation kit that DK sells. Those fit on the front frame downtube. Freewheels should be able to fit either kit, depending on which mounting location you prefer.
DK Custom - ST (03-15-2018)
The following 2 users liked this post by DK Custom:
Clint44 (03-18-2018),
frenchbiker (03-19-2018)
Thanks! Painting them is a solution and it might prevent leaks. In case I want to install black ones, what fittings do I need to buy?
