Anyone order a J & S jack recently?
orientation
bottle jack is facing correctly. If it was turned around then the pressure relieve would be inside the jack not facing outside. And would not have a stud to retain the spring for the foot pedal. The gotcha is if I reverse the bottle jack it will fit the holes and the cup but no stud for the return spring and the pressure relieve is inside the jack. I for one would not put my arm in the jack with my Tri Glide on it.
According to instructions and videos it is correct orientation
My feeling is yes I could drill two holes to make it work but with the money I spent I don't think I should have to do that. I do know I was advised, five or so weeks ago, they had material issues and or with the supplier(the bottle jack)
Been calling all day and no answer. Left message and email regarding this.
I know what the problem is. I found every video i could and looked at the bottle jack. Mine bottle jack is totally different. The videos show the bottle jack being centered on its base. Mine is offset to the right( when facing the jack as if you were using it)
If you look at the picture of the bottle jack you will see it is not centered on its own base. This is causing the issue.
My riding partner just got his pneumatic jack and assembled it today.
There apparently is some conflict with the written instructions vs the video and a different jack part for different model year of bikes (as I understand, might be wrong).
Some of their jacks must be pushed under the trike from the RH side and others must be done from the LH side.
My friend called J&S and he's all squared away.
Assembled the PNeumatic Trike Jack this past weekend, raised the trike, works very smooth.
Pros,
Very stable
Both air and pedel operation capable
Cons,
You have to get the jack very close to the painted left fender to get it under the exhaust and into place
The relief valve to bring the bike down is in the middle of the scissor area and frankly, makes me nervous when lowering the bike.
Did I mention it's very stable
Pros,
Very stable
Cons,
Love mine.. hate the Chinese made bottle jack though.My bottle jack is black not red so maybe they sourced them somewhere else now to resolve the issues they were having. Just this weekend I had the first problem after a year of use. I couldn't raise the jack beyond the second notch in the locks.. Had to remove the bottle jack, add oil, and bleed it. Works fine now.
UPDATE 4/23/2018 J&S jacks sent a new bottle jack and took the old one back- My new one looks like the ones in videos. I think they just had a supply issue and I had gotten an incorrect bottle jack.
They took care of this issue and commend them for excellent customer service! THANK YOU J & S!
ALL IS GOOD!!
ALL IS GOOD!!
I contacted them last week because it had been 4 weeks since I ordered mine. They responded the next day and said they had been having issues with their bottle jack supplier, but now have the problems resolved. They said they are behind on orders by one to two weeks and my jack should ship towards the end of this week. I’m keeping my fingers crossed it does, and I don’t have any issues with the jack.
ALL IS GOOD!!
ALL IS GOOD!!
