Removing the Tri-Glide Body - Photos & Video
My next project will be to replace my heim joints. I know they have play, but under warranty the dealer claimed they were in spec.
Mine will be a bit of a PITA, as I have an audio amp mounted in the tour pack, and a bunch of wires winning in to it. I’m thinking I’ll remove the tour pack, and suspend it from the garage ceiling, then remove the rest of the body.
Replaced the heims in mine a few months ago , as I posted , Harley Davidson does not offer the heim joints , but will sell you the whole track bar for $210.00 ! You can buy heims from a racecar supply house ,ie Jegs or Summit for $6 bucks each ! There is no need in replacing the bar ! Ebert
mctraveler (04-25-2018)
Received 3,939 Likes
Yes, it is the same. Just the connectors at the rear of the seat/front of the Tour-Pak, and then the 8 bolts.
Since I typically work alone, I'll likely attempt to strap the entire setup and lift with an engine hoist, Has anyone had any experience doing it this way, are there any tips or things to look out for, I priced a fender the other day and I sure don't want to damage anything.
Hopefully they will post up...or you may be able to do a search and find where they've talked about it and posted pics.
The following 5 users liked this post by DK Custom:
Cagmo (04-24-2018),
GPHDXLC (04-24-2018),
graygoat (04-23-2018),
mctraveler (04-25-2018),
Tryker Dude (04-28-2018)
