Freewheeler rear wheel change
As a result, the majority of modern cars feature positive offset wheels.
You have it backwards. Positive offset wheels have more backspacing and less dish. Negative offsets have less backspacing and deeper dish. Negative offset wheels create more stress on chassis components and increase scrub radius.
Lon
Adapters are definitely not my first choice but Cragar doesn't make a wheel with the same bolt pattern as the Freewheeler. I did find knockoffs that don't require an adapter but I'm set on the real deal. Right now I'm doing my research for the highest quality adapters.We will see! see.
DWG2015 (06-14-2018)
A high-positive offset wheel (+25mm or more), like those on FWD vehicles or late Vettes and Camaros, tend to put less stress on the bearings than a zero or negative offset wheel. Negative offsets will create the most stress. Stock FW or TG 15x5.5 wheels have roughly a -9 offset. Either a 15x6 or 15x7, with -12 offset, will fit both trikes. The difference between a -9 and -12 offset is less than 1/8" backspacing, a negligible amount.
