Freewheeler rear wheel change
Good morning all. I have a 2017 Freewheeler. I'm looking to do some mods to give it a more hot rod/dragster look. Going to move the brake/tail/directional lights to the trunk and replace with some Custom Dynamics LEDs and remove fenders. The plan is to get a wheel adapter to change from current 4 x 4.25 bolt patter to 5 x 5.5 and put some old school Cragars on. I'd like to go to a 305mm tire which would require a 10"-12" width wheel. Does anybody have an opinion on whether this type of mod will negatively affect ride or mechanical function? Any input would be greatly appreciated.
Received 3,939 Likes
The wider the tire, the more likely it will be to hydroplane.
You may want to beef up your axle bearing retainer plates also...see thread on them below-
https://www.hdforums.com/forum/tri-g...er-plates.html
mctraveler (06-14-2018)
I assume you would be removing the stock fenders. When you decide what route you want to pursue, let me know and I'll help you crunch the numbers.
Just an example but you could go with a 15x8 wheel and 245/60/15 tire. Problem with bigger 15" tires, is the diameter starts getting too tall. Keeping the diameter close to the stock 25.6" would be much easier to manage, with 17" wheels.
Clint is much more knowledgeable about wheels and tires than I am, and he is always willing to help. I would avail myself to his expertise.
I know that the wider you go, the easier you will hydroplane...so it is all a trade off. If you do not ride in the heavy rain/roads that are flooded, then it is a non-issue. If you do, then it is just a matter of trading off what you want for looks for going slower in wet circumstances. Even with the stock tire, on a flooded enough road, and going fast enough, you will hydroplane.
Clint44 (05-20-2018)
