1000 mi. + from home on 14 tri glide with problems!
Sorry to join needing help, but left mi. Last sat on my 14 tri glide that had 1500 miles. 1300 miles later I have been surprised twice with oil pressure light and check engine light upon starting bike. Turned off bike and all was fine. Now couple days later in Deadwood S.D. And same problem but hasn’t reset. Do I need to worry? Heading home in 36 hours and don’t want to hurt this trike. Any thoughts ?
Received 6,044 Likes
Received 3,939 Likes
Did you check the oil and make sure you are not low? If you are not low on oil, and it is not making any abnormal noise, then I would ride it to Rapid City HD and have them take a look...probably the sending unit or a loose connection.
If you are low on oil, do not ride it. Get to an auto parts store and get some oil and bring the level up to midway between the fill and full marks.
Hope you have a great rest of your trip!
