Adjusting a 2017 Freewheeler headlight!
I brought our BN Freewheeler home last night and was quite an unsafe ride home. I could not see anything on the road but my light sure showed treetops well. Why are these not adjusted properly from the factory just like new cars are? Looking today have no idea how to adjust it easily. The 2 bolts and nuts are hidden way up and back behind the chrome fork cover. Can see them but no way can you get a wrench on either. Called the Dealer and am taking it back. They can do it and just a point of view for those buying a new Freewheeler, check the light out before taking the Trike home.
cwn8288 (09-08-2018)
The following 2 users liked this post by RedOregon:
lh4x4 (09-13-2018),
Polarispete (09-13-2018)
The following 2 users liked this post by Coastal CVO:
cwn8288 (09-08-2018),
Having the same problem (2018 FLRT) Mine is looking for snipers in the trees. I'm a new trike owner also. Takes a little getting use too. If you apply the parking brake make sure you disengage it before hitting reverse. you will pop the reverse switch. Look in manual on where it is and how to reset
I also found out its easier to get on if you use the passenger foot rest (I kept kicking my fender,LOL) RIDE SAFE,
JAYDEEIN
JAYDEEIN
