Brake pedal adjustment?
is their an adjustment that can be made to allow the brake pedal to be adjusted lower. Somebody said to just slide your foot over without lifting it up from the floorboard. That doesn’t work for me, even though I have a size 12 boot. If I could just drop the pedal down about one inch it would make a world of difference. Looking for suggestions!
No adjustment on stock brake pedal. Soft Brake, http://softbrake.com/brake-levers-accessories/ makes a great replacement for the stock one. Works great on my RG and wife's TG.
Received 3,939 Likes
There is no adjustment for the brake pedal, via a splined shaft or otherwise.
I use a different brake pedal arm, it is extended and lower, resulting in a Much more comfortable position for using the rear brakes...gives more room for the boot on the floorboard also.
LINK to more details and photos.
Here a pic of my TG.
Here's a pic showing the difference between the factory position and the position with the Extended and lowered arm.
