I’ve had issues with my dang trunk door coming open since I bought my ‘12 TriGlide. I’ve done everything I can to resolve the issue except for taping it closed with Gorilla Tape.
Have there been any changes in the later models that addresses this issue?
Not that I know of. I used to have the problem until I went to closing the door gently and then giving it a good shove til I hear a click.
.......when i first got my trike on 09....i heard about this problem......after i figured the locking system on this thing...i lubed it well....and it operates real good..........i thnk the lid opened up on me once.....and i then started to ALWAYS lock it when i rode.......and guess whut...????...never had a problem.....try that.....and good luck..
All the above is what I do. Close it gently then push closed until you hear it click, then lock it. I squirt WD-40 on it occasionally to keep it lubed. Hope this helps and works for you. I have a 2013 Anniversary Edition.
I use TriFlow once a year on the side latches and lock mechanism. I also use a Silicone spray on a cloth and wipe the seals. When traveling, I lock the trunk.
