hey guys.....is it ok to mix 2 different brands of tranny fluid.......like syn3 and mobil1......i just check the fluid level and it's low......thanks in advance.
I wouldn't, but what do I know. I read somewhere a while back that you should never mix oils. There will probably be many comments here in a few minutes.
How old is the fluid?
I'd change it out just to be safe.
Where do you usually maintenance it?
When was it replaced last?
