Size limit for USB flash drives??
Since posting this I've found that size doesn't matter. The usb I'm trying to get recognized is a SanDisk brand. Just wont work. Other makes do, so I guess Ive answered my own question. Now just have to figure out how to add playlists. Songs in multiple folders just get jumbled all together. I've read somewhere that the answer is a usb hub. Then you can have one drive for country, one for rock, etc. Will have to check that out more.
Thanx Tom84,
Unfortunately, that's not it. Did a bunch of digging after reading your post, and now understand the ins & outs of file system formats.
Both the usb's I have are 4gb and both are formatted FAT32. One is recognized, one isn't.
No big deal at this point, as I just won't use the SanDisk. But being the curious person I am, it just bugs me. I'll keep fishing, and if I find a solution, I'll post it here. For now, the only thing for sure, is try to avoid SanDisk brand usb's.
Pny 16 gb
I picked up a four pack of 16GB PNY at Costco a while back. They work fine, all files are under the root dir. I have seen that the file type and how the encoding is done can cause issues like not recognizing the flash drive when the file in question is the first one the system tries to open.
Well this thread has certainly morphed into something more than what I intended. BUT, I've uncovered some useful info that others might find interesting.
First - forget about my original question. That seems to be solved. At least for me. Don't use SanDisk usb's. I have a 4gb PNY and it works fine. Formatted to FAT 32.
Now for my second problem. Get all my music files on the usb sorted and arranged. So country songs are not mixed in with rock, or pop, or jazz, etc. I found you can join multiple usb's with a hub, but that seemed like overkill.
So here's the answer. Really simple.
1. Create individual folders on the usb and name them whatever you want. Example: COUNTRY, JAZZ, ROCK, MY FAVORITES. Doesn't matter. You pick.
2. Drag and drop all your files into the appropriate folders
3. Now if you were to stop at this point, you couldn't play just the Country songs. The Boom system just jumbles all the songs together into ONE big listing regardless of your nice organized folders.
4. You have to create playlists. Here's how. Go to https://www.oddgravity.com/app-opc.php and download this little program. It's free. Install it and get it up and running.
5. Now go to your folder on the usb drive called COUNTRY, select all the songs, drag them into the app, give the playlist you're going to create a name, (Bob's Big Bad Country Tunes) and make sure you save it to the usb drive. It will save it to the root directory, then just move it into the same folder as your songs. (COUNTRY) That's it. Done.
6. Now when you select MEDIA/USB/FIND/PLAYLIST all your playlists will show up, and ONLY those songs will play.
Hope anyone interested in this can find it buried down in this thread. Good luck...….
The following 3 users liked this post by Captain997:
