Warranty
Received 6,044 Likes
I'd stay married to her, you'd have nothing left in a divorce, just saying ! ha ha
Oogie Wa Wa (10-16-2018)
I purchased my 2013 Tri-Glide on 12/13/12.....got a notice that ESP expires 12/13/18. If 2-year factory warranty plus 5-yr ESP, wouldn't that expire 12/13/19? Dealer said no. They want $2,000 for 2-yr ESP, which is all I can get...only a 2-yr extension from original ESP.
Check your ESP policy.
It's been a long time since I was in school but back then 2+5=7 and I'm pretty sure (even with the new math) it still does.
Not your fault that they cannot either count or read, eh?
Perhaps your salesman made an error on the original paperwork but I'm not aware that they even offered a FOUR YEAR warranty which is basically what they're saying.
Also, if they're only offering a two year extended warranty (in addition to yours that expires in 2019) you may want to do some shopping at another dealer or call the Discount ESP folks and see what they can offer. It doesn't hurt to shop and ask questions.
Keep us informed. This is interesting
When you buy a 7yr extended warranty at the same time you purchase your Harley it will expire 7yrs from the date of purchase. They screw you out of 2yrs that cover the bike under factory warranty. There ends up a double warranty for the first two years that is wasted money.
The way they get away with it is you can see the extended warranty expiration date when you sign the contract !
The only way to get around it is to wait until your 2yr factory warranty is about to expire and purchase the extended then.
Received 3,931 Likes
It's been a while since I checked, but https://www.boardtrackerhd.com/learn...vice-contracts has always had the best deals on the HD "extended warranty". You do have to be there in person to get it. This is a few years old due to the change in HD policy on territories for the dealerships.
Boardtracker sells the HD ESP. They also sell the non-HD ESP, but you can get the HD branded ESP from them also...BUT, only if you are there in person.
The finance guy where I bought my trike was showing me both the H-D plan as well as one from another company.
From what I've been told, the major difference between the H-D plan and the non-H-D plan is that the H-D plan is to be used at H-D dealerships only, and the non-H-D plan can be used at any state licensed repair facility (including H-D dealerships) however, prior to any work being started, the warranty company must be contacted by the repair facility in order to get their approval.
FWIW, DiscountESP offers the lowest rates IF you feel comfortable with them but obviously the H-D seems more convenient.
In between these two is Protective Asset Protection (just a little cheaper than H-D) but they offered me "lifetime free battery replacement.
A major concern for everyone about all of these warranties should be the clause about "Limits and Exclusions" which means that any modifications to your bike "may" void your warranty.
I'm only thinking of possibly a Stage 1 to make the trike sound better and run cooler but if I'm reading it right, even this limited upgrade could be grounds for them to deny a claim if my trike suffered a serious engine, transmission or drivetrain failure.
Another interesting fact is that the "Tire & Wheel" warranty only covers the price of the OEM tire and/or wheel and they have a set price.
If you "upgrade" to a custom wheel and/or tire and then hit a "chug-hole" it will cost you out-of-pocket expense.
BinIdaho (10-15-2018)
This is interesting.
Since the HD tuner and air cleaners are not good choices, and you may or may not like the HD approved exhaust, the way around that it is to not take it in for warranty work without putting it back to stock.
Other items, like a cooler, are not covered by the illegal EPA mandate and can only void the warranty if they are proven to have caused a problem. Again, rather that fiddle around with them, just put it back to stock before taking it in.
On '16 and earlier models the EPA mandate (that is in conflict with the Federal law of the magnuson moss warranty act) does not apply and an aftermarket part can only cause a warranty issue if the part is proven to have caused the failure of a factory part.
Unfortunately the ILLEGAL EPA mandate has stripped '17-up HD owners of their rights under Federal law regarding OEM warranties in regards to the drive-train. Fortunately it is not too difficult to put most Stage I upgrades back to stock to level the illegal actions of the EPA.
Regarding the wheels & tires option, the ESP is an insurance, and they are charging for it based on factory wheels and tires, so that is understandable.
Hmm, now I'm really confused Slou.....I purchased the '13 Tri-Glide on 12/13/12 and added the 5-yr ESP at that time. The number still don't add up. 12/13/12 to 12/13/18 = 6 yrs. 12/13/12 two-yr factory warranty expired 12/13/14, then the 5-yr ESP kicked in, no? Still can't figure out why the 5-yr ESP expires 12/13/18.....shouldn't it be 12/13/19? I'm so confused and dense when it comes to numbers *frowning*. So, I should have waiting until the 2-yr factory warranty was about to expire and then purchase the 5-yr ESP.
You actually gained some. Almost a year.
One thing ,,,, could this double warranty lead to double charging the company for warranty work ??????? NAH !
BinIdaho (10-17-2018)
