Stage III on my 2018 Trike Ultra
STAGE III 2018 Trike
So that is the best news I have heard yet. The 114 apparently has the same stock CAM as the 107 but the Torque Cam has now been included in the lineup. I already have the Torque CAM and want to stick with it with the STAGEIII........Since I live 150+ miles from the Dealer in Boise. I will approach this new info when the Road to Boise reopens in the next two to three weeks.....IDT is working on many miles of Avalanches that cover the Road to Boise...Some are 40-50 feet deep.
Thanks for the updated info on the 2019 114.....
Gary
Gary
sloufoot (03-07-2019)
Stage 3 on my 2020 Tri Glide UltraThe
I recently arranged a stage 3 upgrade on my 2020 Tri Glide Ultra. Today, the dealer called and said I can’t do a stage 3 upgrade because Harley can’t tune it. Of course, I could use another tuner, but then my warranty would be voided.
No stage 3 or 4
i was told that they do not have the mapping to do te stage 3 and 4 for the 2020-2022 i was able to do he stage 2 kit , but on my cvo i want more power
At 70MPH i can get approximately 32MPG and at 75MPG my mileage drops to approximately 30MPG.
Have you checked the highway mileage on your trike?
Sometimes the millage improves when you stay out of 6th gear. Let the engine run free and never load the engine.
A higher RPM doesn't always mean using more gas per mile. This is the reason that sometimes a cam change gets better MPG's. More power and less load on the engine, so actually less throttle ......
ggadwa (03-23-2022)
My best MPG's is between 2500-3000 RPM's which is consistent with my CVO 110 with a Stage 1 kit.
sloufoot (03-23-2022)
Yes that RPM range seems to be the best for both power and millage. Many get below that 2500 range on slower roads and don't understand they are actually lugging the engine down and having to give more fuel to maintain their speed.
