has anybody used this on there trike yet BULLET BRAKE its a parking brake that is i guess to hold front brake on bike locked seen it on facebook web site not all the way up yet
thanks gabe
I use a velcro strap on my front brake lever. I took my parking brake off when I first got the bike because the owner before me had left it on so many times that I had to put new disk on the back. I just use a small strap and rap it around the handle bars when not using it.
Update i was able to get installed over the weekend works as they claim tested on trike on a hill now i will get that ugly parking brake off
The biggest problem I see with is if someone walks past and happens to squeeze the brake handle ..... off goes the brake ! When parked where people can get to the Trike they always have a habit to touch things ! Not in malice, but they like to touch.
I talked with the owner about a modification that you could lock it on and they thought they might later do something like that, but he is pre-occupied with getting things sold right now.
The other thing I see as a possible problem is if used on any type of gravel, you only have a very small patch of a tire holding that heavy weight on any type of a slope. Putting in gear would help and just use this product as a backup. I would like to see something for the rear brakes over the front only.But this will most likely be handy and work for most applications.
Not knocking a good product,but just thinking of ways to make things work better.
I've stopped several times and thought it would be alright just putting it in gear. Then I watched the trike slowly very surge down the hill as the engine turned backwards and the cylinders bled down. NOT good. I got out the Velcro because the parking brake cable was out of adjustment.
