Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Fullsac vs Jackpot Tri Glide Head pipes
Old 05-24-2011, 05:39 PM
Boom's Avatar
Boom
Boom is offline
Originally Posted by robandlyn
Pulling the trigger on Fuel moto pipe (non-coated), Power Vision & Fuel Moto S.E.
air cleaner and staying with stock mufflers for now (Lynn's 2010 Trike with 8k miles) .....
Reason ? GREAT Customer service !
Rob .....
Congrats! You'll love the difference........oh yeah, Lyn will too!
BTW, let us know how that Power Vision works out.
  #102
Old 05-24-2011, 08:16 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Received 4,106 Likes on 1,340 Posts
Rob .....
Thank you very much for your order, if you have any install or additional questions feel free to give us a call anytime
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
  #103
Old 06-03-2011, 08:57 AM
robandlyn's Avatar
robandlyn
robandlyn is offline
Well we dropped off my bike for 2 new tires and asked them if they would
have some time to install the Fuel Moto headpipe & their high flow air
cleaner. I figured for them it would take no time at all but they are so
backed up with work that they are making appointments one month out.
I am mechanically inclined but sometimes things just don't go right for me.
So most times if the parts being installed on any of my bikes get to be
alittle much I have a bike shop do it. When I rode dirt bikes it wasn't a
problem cus I wasn't riding fast and if something WAS going to happen
to fall off or break it was no big deal. But riding on the street with other
vehicles and the speed that your doing I have an uneasy feeling of
something mechanically happen because I forgot to tighten something.
But anyway .... I asked a neighbor who is very good at working on cars and
his wrist rocket to help me install the headpipe and maybe the A/C unit
on Sunday morning. The pipe install seams pretty much straight forward
and I haven't looked at the instructions on the A/C install.
Is there anything I should be prepared to do that is out of the ordinary ?
Thanks ...
Rob ....
Lynn can't wait to see how much better her trike will be afterwards !
  #104
Old 06-03-2011, 08:58 AM
robandlyn's Avatar
robandlyn
Thanks Jamie but your closed on the weekends ;-)
Rob .....
  #105
Old 06-03-2011, 09:58 AM
Boom's Avatar
Boom
Boom is offline
Thanks ...
Rob ....
I hate installing/removing exhaust but that FM headpipe was relatively easy and fit like a glove. I believe I used the exhaust port gaskets that have the taper but someone else mentioned to use the gaskets without (Screamin' Eagle?) for a better fit. Also beware of the gasket for the cross-over pipe. I think mine slipped out. And use anti-seize for the O2 sensors and port plugs you don't use. Have fun!
  #106
Old 06-04-2011, 05:08 AM
msocko3's Avatar
msocko3
msocko3 is offline
Boom pretty much covered the exhaust. You may have some trouble with the bracket the ACR wires connect to. I had to use a allen wrench that was cut down so I didn't have to remove or raise the back of the tank.
  #107
Old 06-04-2011, 06:08 AM
grandpawmoses's Avatar
grandpawmoses
grandpawmoses is offline
On the subject of the crossover pipe gasket, it's like a boxy donut shaped steel wool thing & easy to mangle up (which I did). After finding out that a replacement was a backorder, I reshaped mine & coated it real good with high temp silicone (Permatex copper). That worked out very well. Oh, the AC install is very easy.
  #108
Old 06-04-2011, 06:34 AM
Boom's Avatar
Boom
Boom is offline
Thanks for that info. I guess I'll have to get mine on order! Also should buy the Permatex copper.
  #109
Old 06-04-2011, 06:37 AM
Boom's Avatar
Boom
Boom is offline
Forgot to mention that---a bit of a slow-down on install.
  #110
Old 06-04-2011, 09:31 AM
greyfang's Avatar
greyfang
greyfang is offline
ditto on that bit of a slow down, I also modified an allen wrench but with a little patience, its doable without the tank being moved.
Quick Reply: Fullsac vs Jackpot Tri Glide Head pipes
