Power Vision Problems
It must be protected as there was power in one of the four pins but nothing happened. I was lucky but what is the plug under the seat for? It isn't hooked to the accessory switch since that was off and there was power into. The Power Vision worked great saving the stock download and then flashing a new download. It will hold 6 different downloads, with the auto-tune, it stores the information and then you can flash it to the ECM. as well as set your rpm. You can mount it to your bike and tweak things as you ride. I think this will be great and the original 02's will still work.
Bar_Hopper
05-23-2010 08:08 AM
anubisss
03-08-2007 10:48 PM
