Power Vision Problems
I got the Jackpot Head Pipe installed and then went to download the new map into the ECM but nothing happened.. Plugged the Power Vision into the ECM , turned the switch to the run position, the screen remained blank. Pushed the power button and the screen remained blank. I brought the unit into the house and plugged it into the computer, the screen lit up and said linked to the computer. I could see the one map that Jamie had installed. I am at a loss as too why it will not come on when on the bike.
If the screen is blank it is not powered up and is likely one of the following: Make sure you have the Power Vision plugged into the data port which is under the left side cover, it cannot be plugged in under the seat as this is the accessory plug. Also make sure the igntion switch AND run switch must both be in the on position. If you need any additional assistance you can contact me at 877-729-4754
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Wow talk about dodging a bullet, I'll bet that bugger wouldn't have liked it much with a shot of 12 volts if the accessory switch would have been turned on.
Lucky
I guess what I am asking is there a need for the Auto Tune with the Power Vision and does it have auto tune capabilities?
That would have been my luck, I would have fried it on my dime. Will the power vision be an intrigal unit? I was hoping they would develop a PC-5 with the Auto Tune built in so I could still use my OEM 02 sensors. Was hoping this would bring the price down also.
