TRI-GLIDE problems?
#51
I have not ever heard anything about changing the sprocket to a 30 tooth until reading all the posts here. I have a 2016, help me out here and explain what exactly you are talking about. Which sprocket and where is it located, do you have a part number by chance. Any information would be appreciated especially if it would help the power going up-hill and the fuel savings. Thanks.
You should have a 30 tooth on transmission OEM 70 tooth on Differential unless someone changed them highly unlikely. good luck with power problems. Travel safely Fred
#52
Welcome to the forums, this post Is hidden In a topic started in 2011, I think you should start a new thread with this Info, M8 owners should be aware of this. Thanks for posting.
#53
Ive got the new 2017 M8 with 4000 miles. It was doing great til this past week. Got a mile from the house and engine blew. Under warrenty. They are scoping pistons but cylinder scored up.it was a sudden thing. Went up steep hill to intersection to turn. It idled down to ECT mode while stopped and I applied throttle into turn and all hell broke loose. Went straight back home with it because dealer could not come get it then and told me to take it back home. Harley picked it up two days later. Talked to service manager today wondering if it was compensator and found it to be bigger troubles. The old Dyna never had issues. All this new technology is giving me concerns.
#56
e
Love Jugs Fans lowered temps 20 degrees
wrapped exhaust DEI
Changed air intake Boyesen X force
Air deflectors and raised fuel tank to force air on motor rather than up in face.
added power vision tuner to maximize available power and best fuel air mix to run cooler longer
Love Jugs fans ECM tuner Air intake lose the Cat. in exhaust Lift the fuel tank 1.5 to 2 inches air deflectors remove left side mid frame air shield (give warm air some where to go spacers riders foot boards a starting list of my changes. Everything I have done is to run longer and cooler I have dropped my Eng. temps over 35 degrees on average now we have no real problems with heat. Fred
wrapped exhaust DEI
#57
Engine trouble
HD was great about it. Total Engine rebuild. It took a few weeks but got it back and now at 8,000 miles. All doing well. The culprit was the oil pump. They installed an updated model as part of the rebuild.
#58
Mileage Riden
I have a 2016 triglide that I have put over 20,000 miles and have had no problems. I have love jugs and stage 1 true dulls The bike runs great and has been a joy to ride. I did put on a different seat which helps. Mileage very greatly between 22 MPG at 85\90 to over 40 when driven 55 to 60 MPH. Love my bike
#59
Received 3,940 Likes
There is also a good Report HERE.
